 Originally Posted by
Roulston
				The key question about the value of extended warranty can only be answered through your own appetite for risk. I have signed contracts on a  new D4 TDV6, same I expect as yours but Blue:-)
I have a five year lease and therefore the extended warranty was not a difficult choice for me. I couldn't imagine having to continue paying finance for a car I don't even own and have bug repair bill.
I have owned four LRs but only one form new. These are nicely built and built to last, but they are now so high tech that if they go wrong they are going to cost you.
You should get some competitive quotes because $4k sounds a little high for just two years, it usually is about $1k per year for a late model. And premium very depending on the level of cover and excess. Also check out the limitations if you plan on vey high kms per year as some limit the cover to 200,000 ams, which should only be an issue for an older car or a true road warrior doing 40,000 ams per year.
If you own the car out right, or will after year 3, then the risk is different and one might be prepared to bank (or save) $1k per year which would still not get you a new engine.
I think $4k is way to high for just two years.
Cheers, Tony
