Results 1 to 10 of 11
Thread: Vice Advice.
    May 2009
    Tatura, Vic
    Vice Advice.
    I have obtained from an elderly family members shed clean out an old vice.
    This is a small "Record" brand made in England. Having done some research on this the old Records were a quality vice.
    The problem is it is missing one of its jaws. Irwin tools now have ownership of this brand (probably now made in China) and still supply and sell parts for them.
    All except the one I have. This is a small vice and I don't really have a need for it but I do have an addiction to old quality tools and would like to try to fix it.
    The bloke at Irwin tools could not have been more helpful. He went to great lengths to try and locate one but to no avail.
    I have an idea to maybe get one off a larger vice and have it machined down to suit or maybe get someone to make one.
    Any suggestions.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Adelaide SA
    Like you said, get one machined up.
    Depending on your intended use, you could possibly use some hardwood to make a set of soft jaws.
    Fun fact - balsa is technically a hardwood...
    Farnell sell jaws for Record vices. Is there a no. on the other side of the vice, e.g., 3?
    T3-D - RECORD TOOLS - PAIR JAW/SCREW, FOR NO. 3 VICE | Farnell UK
    http://uk.farnell.com/record-tools/t...ice/dp/1348459
    A new Record vice isn't cheap!
    Dec 2008
    Tewantin, Qld
    Jaws are usually made out of "soft" mild steel, nothing special. It would be easy enough to get a machine shop to knurl up some flat for you if they had a shaper. The cheapest way would be to get them to Knurl up a piece big enough to do both, then cut and drill them your self. Don't believe you can buy piece of knurled flat stock anywhere.
    Shepparton
    Quote Originally Posted by Basil135 View Post
    Depending on your intended use, you could possibly use some hardwood to make a set of soft jaws..
    Or Aluminium
    May 2009
    Tatura, Vic
    Yep it is a Zero. The baby of the range and the only one that jaws are no longer available, from Irwin that is.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    May 2009
    Tatura, Vic
    Quote Originally Posted by crash View Post
    Or Aluminium
    No, want to keep it original.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Sep 2006
    Northern Beaches
    Depending on what other tools you have, I think buy a larger one and cut it down and re drill it. Can you buy one?
    I have a 5 inch vice that I made at tech as an apprentice and I can't remember how we knurled the jaws. It should last my lifetime and a bit more.
    Jeff
    Oct 2007
    Wantabadgery, N.S.W.
    Use mild steel, obtain a checkering file and use a 45˚guide to get you started with the knurling. overlap to keep the pattern parallel. you'll have it done in no time. Drill and countersink, fit to vise.
    Don.
    Huntly via Bendigo
    Dave, I am near Bendigo, if you wanted I have a milling machine and could mill a couple of jaws for you if you needed. Only take a little time to do it.Could do it while you waited.
    Lindsay.
