Thread: Replacement Aerial Options
    Jul 2014
    Hobart, Tas
    Ladies and Gents,
    My 2014 Defender has a telescoping aerial which will never be telescoped back into its closed position.
    What are the options for a replacement aerial which is hopefully shorter, more effective and flexible but not telescoping. Nothing against the telescoping variety but its old tech and I'd be sure there are better options out there.
    New aerial will be installed where existing one resides.
    Cheers.
    Back down the hill.
    What about an electric one that retracts automatically, when the radio or ignition are turned off.
    Somewhat North of Cape York...
    I have one of those short flexible ones on the Discovery, a simple aftermarket model. No maintenance needed and has been withstanding a lot of abuse from objects like tree brances as well as adverse weather conditions. On the Defender I have a standard push-in-pull-out-by-hand telescopic aerial that always stays pushed in as I don't use the radio.
    Johannes
    There are people who spend all weekend cleaning the car.
    And there are people who drive Discovery.
    May 2010
    brighton, brisbane
    Check this out, Bob
    AM / FM / DAB Antennas :
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    May 2013
    WA, South East
    I run a simple straight stainless whip aerial, modified from a UHF jobbie. Was recommended to me by a truckie years ago. Simple, functional, and pretty much unbreakable.
    Tassie/Perth
    If they run on the guard like my older Defender, then I would recommend using one with a good spring on the base. The one I have is able to be retracted by hand down to a small profile when in heavy bush - cheap but works.
    n plus one Guest
    Quote Originally Posted by Trundle View Post
    Same on mine - handled a bunch of heavily (!) overgrown tracks up the Cape no worries.
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    Check out Mobile One Antennas. They specialise in antennas for various applications. They may make an antenna that suits your needs.
    MLD
    Mar 2013
    Feb 2011
    Traveling Aus
    I have a very skinny steel am/fm aerial that one of the previous owners put on at some stage which works a treat. It fits in the original position using a rubber base plate (see mobile one website they are the same).
    It does not retract but it is very flexible and I don't think it will ever break.
    It is only a bit higher then the roof rack but that is a good thing. If the areal hits anything low I know it's going to be a tight fit getting under.
    LOOK HERE
    AND HERE
    The only problem with it is some times it flings back and being steel it chips the powder coat on the roof rack but i'm not too bothered by that.
    I don't think you would have that problem with the fibreglass type ones pictured on the Mobile One website.
    The Mobile One antennas look the go
