Thread: 110 & Stage 1 prop shaft lengths?
    East-South-East Girt-By-Sea
    1.20 MB
    Does anyone know if either of the prop shafts from a stage 1 (LT95) are compatible with the early 110 with the LT95.
    The difference is only 1" in wheelbase, so I would assume that they moved one axle and not both.
    May 2006
    Woolgoolga
    Isn't the stage 1 lt95 output housing different? It could be shorter making the shafts the same?
    1.20 MB
    never had much to do with LT95, well I had one on my 1980RRc when I had one till 1984 but nothing since then.
    Have just acquired a couple of 110 but only one prop shaft and was hoping one of the variety of Stage 1 shafts I've lying around may do.
    I think you'll be lucky Diana - I don't know the relative engine/gearbox position for the two, but I do know that both the front and rear axle locations are different between the Series 3 and 110, with both axles moved back, the back one an inch further.
    If the engine/gearbox are in the same place, then neither shaft will match, although the difference may be small enough not to matter.
    99.87 MB
    The Stage 1 LT95 from my experiences runs the same shaft lengths at the LT230.
    Slunnie
