Results 1 to 8 of 8
Thread: Reverse wire colour code
    Ean Austral Guest
    Gday All,
    I cant find my Rave disc, can someone tell me what the colour coded wire is for the reverse light.
    Many thanks
    Cheers Ean
    May 2006
    Woolgoolga
    Is it for a camera? if so I just wired mine to the trailer plug
    Ean Austral Guest
    Quote Originally Posted by Vern View Post
    G'day Vern,
    Yes it is, so which colour on the trailer plug is reverse.?
    Cheers Ean
    May 2006
    Woolgoolga
    Black. Should be #2 wire. (Not necessarily the second terminal, flat pugs aren't in order numerically)
    May 2006
    Woolgoolga
    Earth is number 3. Just google a wiring diagram, narva site is a good one
    Ean Austral Guest
    Thanks, it would be alright if I could access the trailer plug, bit hard with the long range tank.
    Will have to keep searching for the rave manual.
    Cheers Ean
    Jun 2007
    Margaret River
    Quote Originally Posted by Ean Austral View Post
    Cheers Ean
    Here is the the wiring diagram for lights including reverse
    The wire is Green/Brown
    Attached Files Attached Files
    May 2006
    Woolgoolga
    It seems it hasn't changed then, my 94 rangie is green/brown as well
