Results 1 to 10 of 15
Thread: HELP, where can I get this part!!!
    Jun 2003
    Launceston, Tasmania
    I'm trying to source (locally) a nre hub bearing lock nut and bearing for grover, but the ownder of it (my brither) has decided to have a tantrum about it, so i'm getting it from somewhere else.
    Who would have one????? Parts places, industrial places???
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    whats wrong with british4wd.com?
    they are down your way arent they?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Jun 2003
    They are reasonably close, but don't stock any parts for series vehicles, very usefull :roll:
    I also need an exploded parts diagram for an AVM hub is anyone has seen one, as I didn't dismantle mine I don't know how it goes back together ops:
    1994 Discovery TDi
    SYDNEY -in the shire.....
    are you typing with the sh!ts?
    are you after a lock tab or the large (great big huge) nut on the hub?
    Jun 2003
    well i'm grumpy if that's what you mean!!!!
    Well one of both, the outer locknut and outer lockwasher were both damaged when the wheel came off, the locknut could probably be reused, the washer is just too mangled.
    1994 Discovery TDi
    ill have a quick look when i get home see if i got any floating around.
    do you know if they were the same in the 80s
    Jun 2003
    mine is from the early 80's :wink:
    late 70's would be the same also I expect.
    Thanks for that, it would be of some help if you did have some [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    1994 Discovery TDi
    Rovernaut Guest
    Give Four Drives @ Blackburn sth a call.
    They do series parts. 1, 11A, 111
    03 98900500
    www.fwd.com.au
    fwd@fwd.com.au
    ask them if they can send you their catalogue. it's free and it shows exploded views of part fitting sequence. Very Handy for dismantling.
    Jun 2003
    I've got their catalouge, although I never thought to look there for a hub diagram ops:
    i'll most likely be organising to get the parts from there on monday after all attempts to find one in the whole state of tasmania failed
    1994 Discovery TDi
    Box Hill, Victoria
    If that fails im only around the corner from there. So i can pick up / send if need be.
    Dave.
