It does sound like you have broken something in the front axle assembly - that motor is really too much for the Series drive train, so this is hardly surprising. The most likely is either a free wheel hub or the diff, although a broken axle is a distinct possibility.
I would be inclined as a first step to drain the front diff and see if anything except oil comes out. Once the oil is out you may be able to see something with a good torch and looking through the drainhole and filler hole. With both front wheels jacked up, and a helper turning the wheels one at a time (hubs engaged) you should be able to see whether the axle  (or hub) each side is broken by whether it is turning the diff internals. You will have to rotate the prop shaft until you can see the sun and planet gears.
Of course, if the oil comes out with an assortment of metal, the next step will be to disassemble the axle - to remove the front diff you need to at least partly remove the half axles, which at the front means disassembling the hubs or removing the entire swivels.
Hope this helps,
