Thread: watt meter, where to buy
    Sep 2012
    Adelaide Hills
    i want one of these, or something similar.
    any ideas aulro people?
    thanks
    Last edited by Ean Austral; 25th October 2014 at 05:49 PM. Reason: Please be mindful of the forum rules about naming businesses
    Queensland
    Sep 2012
    Adelaide Hills
    Hi Eevo and what are you going to use it for?
    to see how many amps are going from the solar panel into the battery.
    the one ive mentioned does this job well.
    If you are only measuring current, you don't need a watt meter, just an ammeter.
    Crafers West South Australia
    Chop off the anderson plugs and get a new meter off ebay. From $12 in china or $16 in Oz, including postage. examples:
    OZ E Watt Meter LCD Volt Battery Balance Power 60V 100A RC Ammeter AMP Analyzer | eBay
    AU FOR Analyzer AMP Ammeter Watt Meter LCD Wattmeter 60V 100A Power Volt | eBay
    Sep 2012
    Adelaide Hills
    sorry, i meant i want to measure values coming from the solar panel.
    measuring power, voltage, amps, their peaks and cummulation are important.
    I wouldn't mind one of those myself.
    Sep 2012
    Adelaide Hills
    bee utey you are a bee utey!
    thats exactly what im after
    Queensland
    Quote Originally Posted by Eevo View Post
    Hi again Eevo and for something like solar power monitoring, they are fine as long as the current does not go much over 15- 20 amp, absolute max.
    I have 8 or 10 of the original Doc Watts units and use them for every conceivable test going but they do not work all that well for current loads much over 10 amps.
    The leads on these meters are way to thin and this effects the whole circuit when high currents are being measured.
    Sep 2012
    Adelaide Hills
    thanks. my 80w panel doesn't get close to 15-20 amps. thinking about getting a 200w panel, which should be ok too.
