https://www.facebook.com/outbackandsides
Custom fit out of Defender 110
Pop Top for 110" Defender
including
- Gas strut assisted lifting roof
- Airtex canvas with three large screened windows
- Bed can be lifted as well while supported on gas struts
- Hi-density foam mattress
- Removable mattress cover
- NSW engineering certificate
Mantec Raised Air Intake
- one piece
- for Land Rover Defender Td5 onwards
Fitting of raised air intake and sealed air system
Door Adjustment for Land Rover Defender 110 and 130
Fitting of door adjustments
Mulgo ExBox
including
- 12 way fuse block
- 1x Dual USB Socket
- 1x 12V socket
Fitting of exbox
includes moving vehicle's electronics from under driver seat into the exbox
Steering Guard for Land Rover Defender
- Aluminium plate
- HD steel brackets
- Recovery eyes
Rijidij Off Road Land Rover Defender Tubular Winch Bar
- for electric winch
- including Daytime Running Lights
Side Rail for Defender 110
- with step (treetrunk protection)
- no chequer plate
Fitting of side rails
Gullwing Door for Land Rover Defender
- Glass Door
Fitting of gullwing door
LR Defender 110 TD5 and Puma 2.4 Aux Fuel Tank 45Lt Stainless Steel
Gas Strut Kit for Land Rover Defender rear door
Pop Top Awning Brackets
Fitting of awning and brackets to pop top frame
Hannibal Rear Defender Awning 1.4m long, 1.3m wide
- including LED lights in outriggers
LED lights for Hannibal awning
- for side awning only.
Installation of Hannibal LED lights
- Fitting of LED lights into outriggers of Hannibal awning (side awning only)
- Hardwiring of LED lights (of side and rear awning) with a switch inside the vehicle
Water setup
Stainless Steel Sill-Watertank
- RHS
- stainless steel (food grade)
- 60 litres
- baffles
Fitting Kit for Watertank
- water gauge sender unit
- water gauge
- filler
- filler hose
- water pump 11l/min
- outlet hose
- shower hose
- tap on rear door
- wiring
- switch
Fitting of water setup
Interior Fitout
Storage box LHS cargo area
including:
- two access hatches over wheel arch
- slide-out box with preparation table, large drawer and storage compartment
- cutlery tray
Storage box RHS cargo area
including:
- slide out table with four adjustable legs
Fitting of storage boxes
Gasmate Portable Gas Cooker
- including gas cartige
