Results 1 to 10 of 36
Thread: Optima batteries?
    Sep 2012
    Perth Australia
    Optima batteries?
    Any one had experience with optima batteries for the p38? I'm considering the yellow top.
    Any other battery preference/experiences would be appreciated as well.
    99.87 MB
    Awesome batteries. I use the bluetop in my D2. They are a very long lived battery.
    Slunnie
    Jul 2014
    I also use the blue top marine dual purpose......awesome battery, been in 2. Years so far.
    2000 4.6 HSE Alveston red
    2007 307 xse peugeot
    1974 xj6l jaguar
    Sep 2012
    Perth Australia
    Hey, any particular reason for the blue over the red and yellow?
    Canberra, Australia
    Hammer H,
    Yellow top and blue top optimas share the same internals - both are dual purpose batteries. Blue is targeted at marine users. The yellow top has standard battery posts, while the blue top has posts plus a pair of bolts.
    Depending on your existing battery connection devices (clamps etc) you may be better with yellow or a blue top.
    Traxide kits are setup for yellow top. Only issue ever had with blue top was the positions of the bolts put battery connections very close to metal battery clamp, which meant clamp needed to be modified to allow clearance from connections.
    Have a look on the Marine Batteries | AGM Battery | Optima Batteries site and you will see the differences.
    I sell both the yellow top and blue for $275 ... delivered.
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    Adelaide Hills - SA
    RRTurboD - I am after 4 x Blue Top D31M's.
    Are these available for $275 delivered to Adelaide?
    David
    Jul 2014
    RrturboD, I know where I'll be getting my next one from, I paid $410 for mine...a optima blue marine dual purpose 12v 800cca 66amp.
    1974 xj6l jaguar
    May 2013
    Manly West, Brisbane
    I have the yellow top as my primary battery, the starting crank speed is noticeably faster than the old wet cell battery that I had, also, the ability to accept a much higher charge current is ideal after using the winch.
    I had to swap batteries when the P38 was left for 2 weeks at a fabricator's having work done and the battery fully discharged and died, along with the new battery I fitted a 40W flexible solar panel onto the bonnet with a small solar charger so that won't happen again.
    The only downside of these is the limited reserve capacity but I fitted a 130Ahr deep cycle in the back to cover the power needs without the engine on and I recently upgraded the dual battery charger from a crappy 'SuperCheap' special to a 40A DC-DC Redarc which works much better.
    Feb 2013
    Gosford, NSW, Australia
    Al lot of people have good reports of the SuperCharge All Rounder, I ran one in my 99 and there is an MRV70 in my 96 now, excellent fully sealed batteries
    Steve
    Quote Originally Posted by TheTree View Post
    Steve
    x2 mine are 4yrs old now. One is the main battery for the P38 and the other (105AH) serves multiple tasks including powering a cable-converted 12V cordless drill to fix screws into a wooden deck /uninterruptible power supply for a computer /52L car fridge.... and an Aldi winch which has never seen action on the P38 but is very handy for lifting stuff up 2 storeys to my deck
    The secret is to treat them early with a dose of Innox, don't let them fall much below half charge, and keep them topped up with a proper multi-stage charger.
    supercharge at one stage also gave a sizeable AULRO discount...
    PS speaking of batteries... my bro showed me a battery last weekend which he carries in his "pilot" case. It's about the size of a Samsung Galaxy 5 phone but twice as thick... it can withstand a drag of 200 AMPS (400 in an "emergency") ...two of them in series and he can jump start his C-172 (24Volt system) if it has been idle for a few weeks. It easily started a 4cyl Camry with a dead battery... It has a couple of sockets in the casing to charge mobile phones/computers etc. IIRC it's called a Hi-Tec Multi-function mini jump starter ...
