Oil in booster? Check with landrover that it has had the booster vacuum line recall performed.
Jc
 Fossicker
						Fossicker
						Has anyone experienced this problem on a D3?
95% of the time the brakes work A1, but every now and and then the pedal is very hard but there is no braking retardation. It can happen at very low speeds, normal highway speeds and is very intermitent. This happens when towing or driving normally. No warning indicators showing at anytime when this occurs. Pads and discs replaced 12 months ago and all OK untill recently. Feels like brake booster fails but is only happening intermintently.
Any suggestions would be greatly appreciated.
HUTCHBB
Jc
 Fossicker
						Fossicker
						If you disconnect the vacuum pipe at the booster, you can use a cable tie or similar as a 'dipstick' to see if there's oil in there.
