Results 1 to 10 of 17
Thread: WHEN IS 60cm not 60CM ?
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Answer, it seems when buying a cook top!
    Mum's cook top needs replacing it A 60CM job, but when you measure the actual cooktop top its over 60cms, it's 62cm. After shopping for a new replacement it seems some advertised as 60 cm are actually 58 cms. This also causes problems trying to replace as the cut out holes in the bench top are also different sizes depending on which 60cm cooktop you try to purchase. I went online and found install instructions for different 60cms cook tops opens up a can of worms some will fall through mum's existing bench top hole
    You think there would be some standard, where 60cms means it's 60cms not over or under, over is not so much a problem but when a 60cms is undersize then it's not 60cms is it!
    Townsville
    As an ex chef, I have nothing but disdain for these twonks that design these things. It's all marketing BS!
    Latest euro electro crap.
    Rant begining.
    Will.
    Jul 2012
    ferntree gully australia
    In some way's I was lucky in the fact that I grew in when imperial measurements were the standard , As a young Plumber in the UK the construction industry was one of the first to go over to SI. units . I never had a problem converting to metric . I am still very familiar with both , however I only ever use metric . This is where the problem lies ! Our industry uses mm. not cm. Why cm. is used is beyond me It is so confusing for so many people . As for tape measure's I will only buy them with mm. not cm.+ ft. and ins . Let me explain 1602 mm on a tape with mm is 1602 . Now if you have a tape that is in cm. 1602 cm is 1620 mm. there is a difference of 18mm so you can see It is easy to make a mistake for someone not familiar with both . Sometimes these mistakes can be very expensive !!.. cheers , Jim ..
    1602cm is 16020mm
    Ellendale Tasmania.
    You'll find that a 60CM cook top is the hole measurement that it sits in
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by Redback View Post
    Baz.
    AH, but if the overall top measurement on some is say only 58cm or (580mm) then it will fall through a 60cm (600mm) hole!
    and checking the different tops manufacture's install instructions it has specs for hole size and they all are different so that is the problem
    Ellendale Tasmania.
    Take a tape measure with you
    Cheers Baz.
    2007 BMW R1200GS
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by jimr1 View Post
    I think you did a typo, I think you mean 160cm is 1600mm (1 cm is 10mm , 1metre is 100 cm or 1000mm) The metric system works on 10s
    Sep 2013
    Darwin
    12.74 MB
    Guys, you don't understand...Jimr1 lives in an alternate universe where 1 cm to him is 1 mm to us. Just his conversion, 1620 divided by 1602, allows for expansion of the steel tape over a longer distance
    .... I never had a problem converting to metric...
    I have some doubts about that .
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
