Results 1 to 6 of 6
Thread: Trailer help plz
    Apr 2014
    Blair Athol, Adelaide South Aust.
    Smile Trailer help plz
    Hi all, Im after a No.5 trailer bow or template to make one so I can fit a canvass cover to my trailer. It is a later model poss 1980s. Also would like to get a Nato socket to fit to my series 2a as well. Any help greatly appreciated.
    Cheers Rod
    Hay Point
    Quote Originally Posted by 67hardtop View Post
    Cheers Rod
    If you can't get hold of one locally to get a template, let me know and I will post up the shape and dimensions. They are easily made up from steel pipe and a pipe bender.
    Cheers......Brian
    1985 110 V8 County
    Apr 2014
    Thanks bearman...will keep looking around. If no joy then ill pm you if thats ok.
    Cheers Rod
    Sent from my GT-P5110 using AULRO mobile app
    Cessnock NSW
    Any metal fabrication shop that has a boilermaker should be able to make you the bow in about 30 minutes, that's how I had mine made, cheers Dennis
    Dec 2012
    Snowy Mountains
    Quote Originally Posted by Bearman View Post
    Bearman,
    Do you still have the shape and dimensions for the canopy bow?
    LandroverScott Guest
    25mm OD pipe, 350mm height.
