Results 1 to 9 of 9
Thread: Tidying up electrics under Defender seat / dual battery etc.
    Bracken Ridge, Qld
    I'm going to be putting a dual battery system in (Traxide SC80) but even as it is there are heaps of wires for various accessory plugs etc hanging off the battery terminals.
    It's a bloody mess, and would be a real PITA if having to change batteries.
    Is there a way to run the battery to some sort of sub-rail or something with one + and one - connection, and then wire accessories to that?
    If so, can any recommend an appropriate product?
    (I hope that makes some sense)
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Apr 2013
    Expedition 130 Guest
    I used a couple of 600amp busbars, hooked all the positive and earths through them with cables going to the auxiliary battery under the tray (130 single cab) on the passenger side. Also in the battery box under the seat is the Traxide controller and a Albright solenoid for the winch.
    Mar 2011
    Burpengary, QLD
    I've purchased this from Jaycar recently, and will be implementing it in my revised centre console/cubby/solar charge controller solution shortly...
    10 Way Blade Fuse Block with LED Indicators - Jaycar Electronics
    **EDIT** The Mulgo link posted above also has links to similar fuse blocks:
    http://www.expeditioncentre.com.au/o...use-block.html
    They list a common positive and negative on theirs, though.
    Bracken Ridge, Qld
    Yes what do I actually need as far as that's concerned - common negative and positive, or separate positives or something else? I have no idea about this stuff.
    gone
    1996 Discovery 1
    current
    Nov 2011
    Depending on what you are trying to achieve, but if it something similar to what I am doing hopefully that will help.
    I have 2 batteries under the passenger seat and a Traxide U160 controller and this connects to both positives, the negative both run to the chassis.
    Things I need to run the car go onto the main battery, other non-essential items onto the second, i.e. DVD players the kids, fridge etc.
    Ii am trying to limit the amount of items connected to the battery terminals, so I have purchased an Exbox from Mulgo (which I am waiting on as he is out of stock) and I purchased
    Narva 12 WAY Fuse Block BOX Holder ATS Blade Caravan Dual Battery 12V NEW 54450 | eBay
    Using this it has a 1 common earth that you can use to run to all of you accessories and has 2 positive inputs which could be used for each battery, or both from the same battery, and this is to go into the Exbox and power all the accessories so I minimise the wiring under the passengers seat.
    If you are going to run to an external fuse box like this don't forget to put some sort of fuse that will cover the maximum current as close to the battery as possible in case of a short circuit.
    Richard
    Last edited by Wallaby Ted; 13th November 2014 at 04:43 PM. Reason: Added last paragraph about not forgetting the fuse
    Bracken Ridge, Qld
    Cool seems like a good unit. Have ordered one too !
    gone
    1996 Discovery 1
    current
    DiscoMick Guest
    Those pre-wired Mulgo Ex boxes with 6 or 12 fuses look like a great idea and a simple solution, so one of them is on my wish list.
    Its also possible to get from Autobarn and similar places a circular brass fitting which screws onto a battery terminal and has, from memory, six screws on it, so each wire can be connected separately to it, rather than them being all jammed onto the same battery terminal screw. Costs about $20 from memory.
    As for fuses, I'd instead be inclined to add in a 10am circuit breaker somewhere in the system just in case of overloading. No fuses to replace.
    Bracken Ridge, Qld
    OK my friendly auto elec did the hard yards for me and ran power to where I need it. I now have one of those fuse boxes under the Centre console.
    Ive got an earth, always on power and switched power up to the roof so I can run a reverse camera screen, and interior lights.
    How would I best spilt the power up there? At the moment I'll want to run the screen switched and lights as always on (power wise)
    gone
    1996 Discovery 1
    current
