Thread: wiper weirdness
    Bairnsdale enjoying the rural view no rooftops to see here
    wiper weirdness
    weird occurance when you unlock the car with the remote or dash switch the rear wiper starts to operate ! anyone have any idea
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    Jul 2014
    west of Transylvania
    If you have a spare interior fusebox swap them cos that's the most suspect as the command for central door locking is on pin 7 of IDM and the rear wiper on pin 6(water ingress used to make trouble in there)... also the IDM gets input from the BCU so it's not a simple issue
    just a follow up removed the fuse box (internal) with difficulty and this is what we found
    after about 1 hour of cutting soldering and shrink wrapping the problem has now been fixed replacement box fitted new plugs soldered in
    1996 D1 300TDI GONE
    08 ford ranger c/c
    Not good!
    Didnt consider cutting the board apart and popping the pins out?
    Glad you resolved your issue - chase the leak down causing the problem or it will happen again..
    And look under your flooring - probably rather wet under there...
    No couldn't do that as the plugs were melted into the fuse box so i had to cut it out wire by wire and re solder new plugs on
    Sent from my GT-S7275Y using AULRO mobile app
    1996 D1 300TDI GONE
    08 ford ranger c/c
