Pretty hard to assist when we don't have the benefit of the up close inspections, your local guy and the LR dealer have had.
You talk of a clunk, and then it is a wobble ? Which is it, and when do you experience it ?
The lower arm ( rear bush seems to be the worst ) has a lot of flex or compliance even when new. Possibly to cope with the huge variance in suspension heights, and the resulting changes of front arm geometry. In my experience this lower bush or the adjacent balljoint give a clunk when faulty. This noise seems to occur when mounting kerbs or hitting road irregularities.
If your issue is more of a wobble under brakes, yes the lower bushes can still contribute, but I would look harder at the wheels, tyres, hubs/bearings and the brake rotors, and anything associated, such as the ABS etc.
Drivetrain backlash ? Is this another issue ?
Sounds like you need to spend a little time, and try to isolate exactly what is occuring and under what conditions. The more specific info you can gather, the easier it will be to try and pinpoint an issue.
  Reply With Quote D4  2.7litre
D4  2.7litre
