Originally Posted by
Loubrey
Hi Mate,
The two connections in use is basically an eyelet crimped to the rope (metal or synthetic) which is bolted to the side flange of the drum (used on Warns) and the tapered hole on the drum spindle type which is held in place by a grub screw (This method is used quite seldom). Neither method serves any bigger purpose other than helping you spool the line on the drum.
As you correctly mentioned, the wrapped rope on the drum is the actual connection and the basis for the associated strength.
So answering your question, drilling the crimped hole a bit bigger will make no difference and certainly won't make it unsafe to use.
The intriguing question is the nature of the "nipple" you are describing... Is it actually like a grease nipple screwed into the flange (possibly using the actual connection hole)? If so, it would actually be prudent to just replace it with a domed allan head bolt in the right size as per original (M5 x 10mm if I remember correctly) which will most probably mean the hole in the crimp is the correct size to begin with.
Lou
