                                                24th November 2014, 06:57 PM
			Child Car Seat Restraints
					I have a 2009 Defender 110 Twin Cab & would like to know if anyone has fitted child car seat restraints ???
                                                24th November 2014, 08:10 PM
					You might have trouble getting engineering approval if it is needed where you are. There are some good threads and a link to a not exactly legal but more than strong enough solution as a sticky in The Good Oil page of the forum.
 I did the bar across the cabin bracing thing, works good.
                                                24th November 2014, 09:33 PM
					probably not fully up to standards but all's I've done is loop and tighten the rear strap of the child seat around the two 10mm solid rods of the head rest.  I don't need an engineer to tell me that it will be as strong or infact stronger than the pressed about 3mm thick clip that you normally clip too.  Just make sure the actual seat is fastened properly.  Works for me.
 cheers,
 Andrew.
                                                25th November 2014, 07:05 AM
                                                #4
					I had one made up and approved for my 2004 double cab, should be the same as the 2009. It is fairly simple, uses the bolts that hold the rear window panel to the tub.
                                                25th November 2014, 09:25 AM
                                                #5
					Thanks for all your replies I'll take them on board and work out the best way to go!!!
 Cheers George.
                                                26th November 2014, 01:33 PM
                                                #6
					Some photos of mine are here, there is also a lot of other info in this post.
 Child seat anchor points for Defender 130
                                                26th November 2014, 03:35 PM
                                                #7
					I made my own isofix anchor points and used isofix seats.  By far the best and safest option, in my opinion.
                                                26th November 2014, 04:41 PM
                                                #8
					You might like to check out this thread ....
 Child restraint anchor points
