Results 1 to 10 of 35
Thread: Series Land rover Chassis?
    Apr 2012
    samford
    Hi guys I know that the Toyota Land Cruise chassis is different for the ute and SWB..
    Hence why the SWB is better in the real rough stuff..
    So I was wondering is this the same for series land rover's
    Like is a series 1 80, 86 inch chassis more flexible than say the 107 ute or wagon?
    And is the 88 inch series 3 chassis more flexible than the ute 109?
    A Land Rover chassis is a box section, welded together from mild steel flat plate. It is designed not to flex.
    Aaron
    The advantage of swb in "real rough stuff" is the better breakover angle and that less axle articulation is usually required simply because the axles are closer together. (Actually, Series Landrovers have better articulation anyway on swb because on lwb (after Series 1) springs are set further out on the rear axle).
    Actual chassis flexibility does not enter into it either with Landrovers or any other modern four wheel drive, although the Landrover chassis really is less flexible than some others (e.g. Landcruiser), even in these more flexible chassis the amount of axle articulation that is gained is negligible compared to the axle movement allowed by the springs.
    If you want to experience chassis flex, try a 60cwt Blitz with no tray.
    Aaron
    Quote Originally Posted by Aaron IIA View Post
    Aaron
    Most trucks rely on the tray or other body fitted to provide a lot of the rigidity, so you would see this with almost any truck when driven with no body over rough ground. Most cars and four wheel drives with separate chassis rely on the body to provide rigidity, and find this necessary, if only so that the doors will open and shut when parked on rough ground.
    Series Landrovers and their derivatives differ in the sense that nearly all their rigidity is provided by the chassis, allowing flexible body options and keeping the centre of gravity low.
    WA
    I disagree with the entire premise of the question. Sure swb vehicles have better breakover angles and turning circles, but ime lwb vehicles are inherently better offroad. However lwb vehicles often come with overly stiff springs, which gives a false impression of swb ability.
    Jul 2012
    midwest W.A
    but ime lwb vehicles are inherently better offroad. .
    In the really heavy stuff?
    Surely you jest!
    Aug 2012
    Adelaide
    I think LWB vs SWB is a horses for courses thing.... comes down to what you want to do and where you want to go more than the actual vehicle capabilities.
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by debruiser View Post
    Have to agree, SWB are better at sharp turns, but can fail in situations when rear axle traction is lost before front axle traction is gained and this is where the LWB are better than SWB. It often doesn't matter about the articulation, in fact articulation without traction is no better than a suspended wheel.
    There is no perfect 4WD for all situations!
    I think that about sums it up, but the OP's question was about the subject of chassis flexing adding to offroad ability, using short vs long as the example, and the answer to that is that it is irrelevant.
