Thread: next hurdle - the carby
    Jul 2013
    ravenswood, Western Australia
    Hi everyone,
    after sorting out the issue of getting fuel to the carby, i now have another question (surprise surprise)
    If any one has time are you able to take a snap shot of the way your throttle linkages are connected to your carby.
    for some reason i can't work it out, when i connect them to the carby it pushes up rather then pull down??? i am sure it will be a newbie mistake
    cheer for your help everyone
    PS: it ran really well this morning considering it has been idle for 8 years, started on the third press of the button
    JDNSW's Avatar
    Which carburettor?
    Jan 2014
    coes creek
    I have the 2.25 with a zenith if you need anymore ask if it's the same as yours
    Jul 2008
    Is the lever that connects to the rod that runs across the firewall arse about face. That's the lever at the back end of the connecting rod to the carby linkage.
    JDNSW's Avatar
    Quote Originally Posted by jamesnedtaylor View Post
    Try this - sorry its a bit blurry, but you should be able to work it out.
    Jul 2013
    ahhh yes it would help if you all knew what carby i have hooked up
    we currently have a holden stromberg fitted, this carby was the carby that was on it when we last had her running (7-8 years ago) so have fitted it for now as we know it worked fine last time. After firing her up today i can say she still runs good on the stromberg.
    We have just got to work out the linkages for the throttle on the carby end.
    will now go back and read your helpful posts
    cheers everyone
    Jul 2013
    well after digesting all the photos and info, and having a beer and pizza this is the final outcome with the help of Jamesdtaylor, John and Chopper.
    It works so i must be close enough
