Results 1 to 10 of 36
Thread: SE to HSE
    Jan 2013
    Sydney, NSW
    SE to HSE
    I've been a little OCD about some of the switches in my 1996 SE not working, and after a stop at DPL today, I was informed that someone had replaced the indicator stalk with one out of a HSE, which has a trip computer and a speed alarm.
    Apparently the SE doesn't have these fitted.
    Has anyone fitted a trip computer (that shows fuel use, etc.) to an SE? How hard is it?
    Aside from the sunroof (I hate sunroofs), what else does a HSE have that an SE doesn't, and is it easy to fit?
    --Striker.
    Feb 2012
    Carnegie
    Electric leather seats.
    Do you have a subwoofer.
    Fog lights. Headlight wipers.
    Do you have steering wheel controls?
    I suspect the trip computer is part of the BECM. I wonder if it can be enabled.
    Douglas Park, NSW
    I suspect it may need to be a high line BECM, like the type required for memory seats/mirrors.
    There's lots of little differences too. While I had my DSE apart recently, I fitted whatever HSE bits I could.
    More footwell lights, map lights, ign switch light, puddle lights...
    Still need to swap the ABS modulator & ECU to get TC & will probably fit memory seats/mirrors too.
    Centre console cup holder also.
    Mar 2009
    Bexley NSW 2207
    i even ask the the guys at Rover Australia about these at the time and it seems there was no set model type. some had headlight washers some had sub woofers, some had highline becms (H on the paper label) some had clarion stereo and steering wheel switches.
    without modification a lowline becm cannot run electric seats, seat heaters, front foglights or possibly the sunroof, but most of the other stuff can be programmed in if fitted with the appropriate switch and wiring. but without seeing the car and working out exactly what is or isn't hidden away it is impossible to know what will work.
    Douglas Park, NSW
    Quote Originally Posted by Rupert Prior View Post
    SE's had Clarions - it was the poverty pack S that had the Eurovox head unit. I think that the S could be the only RR here that might have had the low line BECM as most SEs that went through Trivetts were optioned up with fog lights.
    Jan 2013
    Sydney, NSW
    Quote Originally Posted by davidsonsm View Post
    I've got headlight wipers, and steering wheel controls.
    Two misses on the seats, they're not leather, and they're not electric.
    How can I tell if I have a subwoofer?
    --Striker.
    Jan 2013
    Sydney, NSW
    I've got a puddle light on the driver's door, not sure if I have them anywhere else. I've got map lights, and an ignition switch light also.
    --Striker.
    Jan 2013
    Sydney, NSW
    Would you know if the same loom is used for the SE and HSE?
    If so, it might just be a case of a new BECM to get some of these things working, then I'll need to go chase some foglights and electric seats.
    --Striker.
    Douglas Park, NSW
    Quote Originally Posted by Striker View Post
    --Striker.
    You should have electric seats now. HSEs just had a position memory too.
    If you need to go to the hassle of replacing a BECM, then I'd suggest being happy with what you've got now.
