Alternate Jack.
Fault Code Reader / Clearer.
Multimeter.
Hi Guys.
Thought I would start a sticky thread on what you believe are essential travelers spares for the D3 D4 RRS.
At Gordons GEO seminar he says carry at a minimum.
Wheel speed sensors.
Height sensors.
Airline repair kit.
Please add what you guys carry and what you belive we should be carrying on an extended tour.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Alternate Jack.
Multimeter.
2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
Yes but, (words of wisdom from Gordon again) always carry the OEM jack too because there is almost nothing else that will get under a D3 / D4 if the suspension has dropped on it's bum. The crappy scissor jack is needed to raise the vehicle enough to get a proper jack under it.
2024 RRS on the road
2011 D4 3.0 in the drive way
1999 D2 V8, in heaven
1984 RRC, in hell
Thanks Andrew,
This thread is a good idea.
Part numbers would be a big help as well.
 Fossicker
						Fossicker
						I'd add in - brake light switch, a few bulbs for brake / reverse and park lights and a few fuses. They don't cost much or weigh much but could very well be useful.
If car is older and hasn't had water outlet housing or the larger turbo hose changed these might also be a good idea.
And a fault code reader which I still haven't got around to getting....
 Swaggie
						Swaggie
						Spare rear suspension link rod bolts RYG501580.
 Wizard
						Wizard
						I have in my kit the following:
2 x suspension sensors with rods (front and rear)
1 x brake switch
2 x suspension link bolts (on order waiting for them to arrive), need to add a left hand drill bit and carry a battery drill when travelling.
I also carry a breaker bar and socket for the wheel nuts.
I will add an IID Tool, GOE emergency air kit and wheel speed sensors.
I only carry the brake switch and suspension sensors day to day and the rest when I travel.
Fuji white RRS L494 AB Gone
2023 Ford Ranga
Thanks for the thread.
It would be extremely helpful if part numbers could be provided as well...
Regards, Will
LLAMS, FYRLYTS, OL D4 Bar
I carry;
Spare air filter
wheel speed sensors F & R
Faultmate and laptop
Height sensor and rod
6th spare wheel on long trips
Rear suspension link rod bolts (RYG501580)
Cheers Baz.
2011 Discovery 4 SE 2.7L
2007 BMW R1200GS
1979 BMW R80/7
1994 Yamaha XT225 Serow
 Wizard
						Wizard
						Some of the part numbers are dependent on model and Vin.
Brake switch is XKB50110.
Suspension sensors are Vin dependent. Try Landrover Parts Catalog for part numbers
2023 Ford Ranga
