Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: Dual Voltage Perenties. Do you use the 24V side?
    East-South-East Girt-By-Sea
    1.20 MB
    In the process of setting up 48-852 am wondering about other uses of the 24V radio system.
    On my SIII FFR I have an additional 12V dist box for accessories which means the 24V system only gets used for the green radios, which hardly ever get turned on. A waste of the 24V system and the batteries.
    On this vehicle I'm considering getting a larger but now 12V-24V fridge but am wondering what others use their FFR/RFSV 24V system for?
    Western Victoria
    I have a 2000W pure sine wave inverter and a 24/12V DC/DC converter on mine.
    I use it as the second battery when camping.
    If your going to remove yours, I'd be interested in the generator.
    driving inverters,fridges, lighting rradios and welding with.
    Oct 2014
    Hervey Bay
    24v lectral system
    Hi lotz-a- lands I am using my 24 volt system to run a hydrogen generator which I purchased from company in Western Australia but I am only using 2 batteries to give me 24 volts and I have fitted the gas generator on the left hand side were the other set of batteries where fitted, I have removed the electrical switch board that was fitted to the vehicle and draw power from the batteries, using the 24 volt alternator to charge the batteries, it has more than enough capacity to handle the requirements o the gas Generator .
    That's one option for you .
    Take care have a safe and merry Christmas
    1.20 MB
    Quote Originally Posted by brad56 View Post
    Are you insufflating the hydrogen over the diesel?
    Oct 2008
    Heart in the Deep Nth of FNQ,Body in the Deep Nth of Brisneyland
    Diana, RFSV runs dual 12v with an isolator.
    Only FFR is 24v on the radio side.
    Cheers, BDave.
    Replace "You are...!", with "Are you...?"
    Army Land Rover Buyers Guide.
    buymilitaryvehicles.com
    Reunited with RFSV 51 680, 'Sleazy'!!
    '00 VeryDisco TD5 Auto,
    Nanocom Evo for D2 TD5 and Puma
    Gone:RFSV, 51-699, Carryall 48-358.
    33º 29' S 150º 13'30" E
    Pass me the Thesaurus please. Oh, I see, it's a medical term for blowing something into a body cavity. I'll keep that handy for another time.
    insufflating
    "In the 18th century, the Tobacco Smoke Enema, an insufflation of tobacco smoke into the rectum, was a common method of reviving drowning victims." WHO WAS THE BRIGHT SPARK WHO THOUGHT THIS MIGHT WORK?
    1.20 MB
    Quote Originally Posted by 303gunner View Post
    insufflating
    Is it not also used in automotive terminology when you add LPG/CNG/Hydrogen over diesel fuel (usually about 25%:75%) to create a cleaner more efficient burning engine? (Otherwise called Diesel-Gas)
    BTW: You should be using a dictionary or encyclopaedia, not a thesaurus!
    I'd never heard the term before (and I'm sorry I looked it up ), but the addition of another fuel source to the diesel combustion cycle is common, either as a gas as you mention, or as a liquid additive to the diesel (ie Diesahol fuel, a blend of Diesel and Ethanol has been used in Sydney Buses to reduce emissions and enhance economy).
    I think it has been shown conclusively that the energy required to generate the Hydrogen far exceeds the energy created in the more efficient burn, but it does have advantages in reducing emissions and oil contamination.
    Near Seven Hills, Sydney
    I use my 24V system to run my fridge and UHF radio directly, and have a $99 24v/12v step down from Jaycar to run my cig and USB adapter. Do make sure you fit a low voltage protection circuit, such as the Baintech one, on each circuit, as, for example, the 24/12 reducer will happily step down to 12v with an input of just 18v, which will effectively damage a deep cycle battery.
    Ask me how I know, $450 of batteries later
