Hi,
If you have installed a relay for your headlights then the relay could have some welded contacts and stuck in the on position.
What lights are on? High beam or low beam?
If you haven't installed any relays then it's probably your steering column switch that is stuffed (Not your head light switch).
Or it could be a short to active in the wire going to your headlights but that sounds unlikely.
It's hard to say.
Cheers.
