I am still using human power for my canoes and kayaks, but I have thought for some time that if I became too decrepit to paddle that I would fit an electric outboard to my canoe.
A canoe with a flat transom may be slightly easier to fit the motor, but it isn't particularly difficult to fit a bracket that mounts the motor on the side. In fact you can just use the clamps on the motor to clamp it to the side of the canoe with no extra brackets.
I wouldn't consider a petrol motor for two reasons. There are places you are allowed to use electric motors where petrol motors are banned. A good canoe moves along at quite a respectable pace with an electric motor, so you don't need anything more powerful.
I believe that if you are thinking of sometimes having two people on board, then about 15ft or 4.5 metres is the size you should be looking at. Much shorter than that and it becomes slow and has to be wider to get the necessary volume and stability and that makes it awkward to paddle.
if you are by yourself, I think you could put the battery right up at the bow and the canoe would then be trimmed reasonably well.
There is a bit of a discussion on this site about the size motor needed and there is quite a bit of information on other sites if you do a bit of a search for "electric motor canoe" or similar.
http://www.ausfish.com.au/vforum/sho...tric-for-canoe
You might be surprised how little power you need for comfortable cruising and good range.
