It's a bit like the propshaft gaiters.
Great idea until someone stands the vehicle in deep water, the gaiters fill up but don't drain afterwards....sliding joint buggered.
If you were intending to do a lot of high speed Kms on dirt roads then maybe useful but otherwise I'm not sure. My Series I had 2 small pits that I had to fill with epoxy metal, not bad from 1956. My '95 Defender has had the liquid grease mod in the past and still on original balls & seals. Series II is OK but needs seals same with a couple of others.
My Series III shorty had some bad wear marks in one spot, looked like a combination of a wheel shimmy & sand getting behind the seal. Filled with epoxy metal and doing OK at the moment.
The problem seems to be when LR's are parked up and the grass grows  underneath holding mosture around the swivel balls. If they are shedded  or used there is less of a problem. Mind you making the seals too leak  tight might also be a problem, a slight weep and the balls are  lubricated externally.
Now if you filled the inside of the gaiter with grease, that might work......
Colin
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
