Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: long range fuel tanks, good idea?
    May 2010
    brighton, brisbane
    Considering putting a long range tank in the D2. Any one done it, any problems with it, good idea, or not? Bob
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    Sep 2012
    Adelaide Hills
    ive done it. using long range automotive
    replaced my 90l main with a 150l
    and added two side tanks of 51l (you can have one fuel tank either side as long as the vehicle doesn't have factory air suspension or ACE)
    total 252l
    total cost was 4.1k
    it was installed by my local TJM
    issues:
    on my first major trip away the main tank developed 2 hairline fractures at about 7,000km. TJM fixed the tank no questions asked. was happy with their service
    ive also had issues with the side tanks. kinks and/air bubbles in the lines. unable to transfer fuel to my main tank. TJM fixed it numerous times but we're unable to come up with a permanent fix.
    i ended up fixing it myself using different lines and connectors.
    the great thing about the size of the main tank is that each dash on the fuel gauge represents about 100km with the v8 engine. (about 18l/100km)
    would i get them again?
    i think so. expensive but necessary for areas of travel. i still carry 5 jerry cans but i can drive to pt hedland to alice springs without filling up ( i really hate stopping )
    Sep 2012
    Adelaide Hills
    i also had to get the aftermarket side steps/rock sliders altered as they use common mounting points. cost was about $300 at a metal fabricator.
    The tanks smdesign for the side slung tanks has known house routing issues that causes the stock fuel line to kink and collapse. the routing also creates p traps that prevent the tank from venting correctly if you have the setup that fills from the commonnfiller.
    The solution is to use a more rigid nylon line and a modified routing of the breather lines.
    Its been an intermittant issue since the D1 setup.
    No issues at all with the Brown Davis 140 litre tank. For a one off situation it is easy enough to get four 20 litre jerry cans across the rear foot well. This is how i set up for fuel on the Canning several years back. I still have the false floor I used for this if you want to look at
    Dec 2009
    Baldivis WA
    The thing I don't like about a big rear tank is the extra weight behind the rear axle. The max rear axle weight isn't very high.
    I'd be looking at twin sill tanks, extra weight between the axles, low down, plus you now have 3 seperate storage containers.
    Feb 2010
    On the Murray at Echuca
    Bob
    I put in a Brown Davis tank when I thought my original plastic tank had a leak. It didn't, but I'm quite pleased with the extra range none the less.
    The BD is well made, although I think volume is down to about 120L after multiple rock impacts.
    I still carry jerries on major trips.
    With the gas injection system of 20 L propane I get quite a useful range from the car, although not enough to get from Port Hedland to Alice. Luckily there is fuel at Kunawarritji, Kiwirrkurra, and Kintore.
    Bob
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by Roberto View Post
    Bob
    for $3.15 per litre
    Adelaide
    I use a Long Ranger tank, 135 litre, no issues and seems strongly built, surviving several hard scrapes. At least 125 litre useable. Easy to fit, changing the pump is easier than with standard plastic unit due to locking ring design. As mentioned they do add to rear axle load when full.
    Im in SA, so no roadworthy checks. How do others in states with vehicle inspection laws fare? I have heard NSW for example requires an engineer's certificate for aftermarket high capacity tanks.
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    I'm a little puzzled as to why you would fit a 135ltr tank but only able to use 125.
    Do these long range tanks bolt straight up where the standard 90ltr sits.?
    What happens with fuel pump and level float?
    I have never had an issue with endurance but if I had a 140-150ltrs I would never carry a jerry again.
    There is no where in Australia where you need 1500km range anymore.....ie unless you refuse to refuel at local prices.
