8th December 2014, 10:29 PM
ABS Warning Light
ABS light keeps coming on when riding over rough terrain bumps etc.only stays on for a moment.
ive been advised to clean brake sensors so can someone advise me where i can look at a diagram/exploded view of brake setup
thanks
8th December 2014, 11:00 PM
Brake sensors, one on each hub. They just push in, or out.
They should be self adjusting, ie you push them in as far as they will go and the rotation of the exiter ring pushes them out to the correct level.
I would remove, clean and lightly grease before refitting. They do go faulty. The sensor pushes into 7 / 8
9th December 2014, 10:01 AM
Fantastic. thanks so much for your help.
9th December 2014, 10:05 AM
#4
Could be a wheel bearing /hub on the way out.
Regards Philip A
Nanocom should tell which one is at fault.
Reason: more info
9th December 2014, 11:55 AM
#5
9th December 2014, 11:37 PM
#6
10th December 2014, 12:58 PM
#7
Originally Posted by
tommo457
nanocom?
Diagnostics unit.
10th December 2014, 02:08 PM
#8
