Results 1 to 10 of 13
Thread: roof rails?
    Jan 2013
    Adelaide, SA
    roof rails?
    Hi all,
    I have been putting this off for ages, but it is time to do something about rails and or a rack for my D3. The previous owner took his 3/4 rails with him so I have two open grooves on my roof with the bolt holes exposed to the elements. Has been this way since I bought it so hopefully I haven't had too much water ingress.... What are my options for rails? I got a quote for Thule racks with rails for about $500 but I have no idea what else I could do, or what options limit me for other racks. I do like the look of Baja Racks. Over to you!
    Dec 2010
    Quote Originally Posted by morpheus View Post
    Hi all,
    You can get little plastic caps from autobarn/repco that you can shove into the exposed holes to start with.
    Mar 2007
    Kalgoorlie WA
    Have a look at the new style of Frontrunner / Windcheater roofrack for the D3/D4.
    The older style (which I have) has six "legs" that connect the rack to the roof. This style has been replaced by what appears to be a long "channel" that sits down on the roof where rails / track would normally go. Might kill two birds with one stone.
    From what I've seen, the new style places the rack slightly lower than the one I have, which is not a bad thing either.
    Cheers .........
    BMKAL
    Feb 2012
    Wollongong
    Although I have a general aversion to roof racks (glass roof), I do like the look/practicality of the 3/4th length rhino rack thingo (the flat tray one with short legs). Such as - Pioneer Platforms | Rhino-Rack
    If you weren't going with a rack, you could source the required bits from TRS in Adelaide from a wrecked vehicle or eBay.
    Jan 2013
    Adelaide, SA
    Thanks all!
    I will get the exposed bolt holes plugged as a matter of urgency - thanks for the advice. I didn't even think of autobarn.
    The frontrunner rack looks quite nice, BMKal. Hmmm.
    Anyway, now I have some options. Thanks again.
    Dec 2009
    Ranelagh, Tasmania
    Rhino also do channels, they are lower profile then the Landrover ones and cheaper.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Mar 2007
    Kalgoorlie WA
    I might have the advantage of being able to do a direct comparison ........
    Parked downstairs under the office are two D4's -
    Mine, with a full length Fontrunner / Windcheater rack, and
    My bosses with a 3/4 length Rhino Platform.
    I definitely prefer the Frontrunner on both appearance and strength. Mine is also slightly lower than the Rhino. The new Frontrunner is even lower than mine, and I believe would be better again.
    Just my opinion of course ............
    Cheers .........
    BMKAL
    Dec 2010
    Thanks all! I will get the exposed bolt holes plugged as a matter of urgency - thanks for the advice. I didn't even think of autobarn. The frontrunner rack looks quite nice, BMKal. Hmmm. Anyway, now I have some options. Thanks again.
    If I had time I'd look up what the bit is called. My local auto barn had a whole rack of assorted 'plugs' of various sizes.
    A word of warning though- make sure it's not too tight a fit, and lubricate the plug. I almost broke one off in the hole, which would have been a major pain!
    Jan 2013
    Adelaide, SA
    Thanks! Just found that out. Took a different car up to autobarn and they had heaps of different size grommets. About to take the Centurion back up there now!
    Feb 2012
    Wollongong
    I think there are a bunch of different height legs for the rhino rack and that a very short set will make it mount very low but are not on the list of d3 compatible legs or something like that.
