Is there any need to use a winch rope blanket with synthetic rope?
Hi I came across this on YouTube and thought it might interest some people. [ame]https://www.youtube.com/watch?v=StZHlHD09XM[/ame]
gone
1993 Defender 110 ute "Doris"
1996 Discovery 1
current
In a word, no. It would often save interference and dark muttering from sideline experts to use something. The stored energy in a synthetic rope is virtually zero.
You should still maintain a healthy respect for any recovery gear whilst in use - idiocy and injuries are not just close in the dictionary
Sent from my HTC One XL using AULRO mobile app
1999 Disco TD5 ("Bluey")
1996 Disco 300 TDi ("Slo-Mo")
That's exactly what I thought -just confirming. Thanks.
gone
1996 Discovery 1
current
The only faults I could see were the angles created when they were using the snatch block for change of direction to get a straight pull up the centre of the track.
At those angles above 90 degrees the tension on the cable doubles, i.e. the load being pulled was say 1 1/2 tonnes, the load on the cable either side of the snatch block would be 3 tonnes each side. Which means the load on the snatch block/tree anchor strap would be 6 tonnes, it was not mentioned, but should have been, anchor strap loads should be mentioned as loads on this part of the rigging setup are usually the highest in the system, otherwise a good lesson, Regards Frank.
