Thread: carbi rebuild specialist
    Nov 2007
    Cedar Grove SE QLD
    Hi guys I have obtained a correct 1950 date stamped carbi for my "shed find" 80" to replace the holden one that it has fitted my question is can any one recommend some one that can over haul or rebuild it? It doesn't seam to have a lot of ware but I would rather have it checked out before I fit it?
    numpty's Avatar
    numpty is offline TopicToaster Silver Subscriber
    Nundle
    I had one rebuilt for my '88 a few years ago by Duel Fuel in Caboolture. Don't know if the still exist.
    They did a good job, even making a new jet to replace a wrong sized one.
    Numpty
    REMLR No 143
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    mike now works from home
    Telephone: 07 5498 3300
    is the last number i have on him
    i hear there is a guy in tassie also but i know nothing of him
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    JDNSW's Avatar
    There's a bloke in Dubbo does carby overhauls - I don't have any experience of his work, but I got a quote from him to overhaul the Zenith on my 2a, and decided that a new one was cheaper - and replaced the coil, fixing my "carburettor" problems anyway! Let me know if you want his details.
    Avoca Beach
    I saw NEW Series 1 carbs advertised in this month's LRO IN UK for about GBP110.
    Regards Philip A
    Jan 2013
    Townsville Qld
    Quote Originally Posted by Lost Landy View Post
    G'day Lost Landy,
    I recently had my '49 carby re-built/serviced by Carburettor Service Co. in Sydney. Great job and very happy, works perfectly. It took about 2 weeks including postage and cost approx. $320 including freight.
    URL="http://www.carburettorservice.com.au"
    Hope this helps mate.
    Dean
    Nov 2007
    Cedar Grove SE QLD
    Thanks for all the advice guys, I have seen the new remanufactured carbis but there for the 2 litre engine and arnt jetted to run the 1.6 (they over fuel)
    Will call a few places that you guys have recommended and see how it goes
    If that was my problem of the carby over fueling, I would try to compensate by dropping the float level slightly by fitting a thicker washer between the needle valve and the cover.
    Otherwise, getting the correct size jets fitted by a specialist is the only option left.
    Just a thought, if you make up a oxygen sensor coupled to a meter, that could be temporarily be fitted while you experiment with the different jet sizes and settings, it would then allow you to monitor changes without the expense of using a workshop with analytical equipment.
    Kippa Ring
    Quote Originally Posted by incisor View Post
    That's still his number. He is in King St Caboolture up the Wamuran end. Very nice bloke to deal with.
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
    95 Disco v8 - The Next Victim
    numpty's Avatar
    Nundle
    Quote Originally Posted by wrinklearthur View Post
    Preaching to the converted and knowledgeable no doubt but all Series 1's run the same carby albeit with different jet sizes. The 1.6 has a smaller venturi also. I have the jet sizes written down somewhere, but someone has my Series 1 manual (Glen)?
    Numpty
    REMLR No 143
