Hi Ean,
If you do attempt the cleaning of the EGR valves may I wish you the very best of luck. If you are going to take them off to clean them might I suggest you fit new ones, you can get them cheap enough from the UK.
When you do the one on the left hand bank make very careful note of where the dipstick tube goes, you have to take the tube out to get the EGR valve off. I dearly wished I had taken a more careful note of the route it took down the side of the engine. Photographs etc.
Yours is an 08 so the EGR valve has to go back............
