Results 1 to 10 of 12
Thread: Auto electrician time
    Williams West Aust
    Hi Guys.
    Been busy in the shed wiring up the D4.Fitting a Traxide Tronics dual battery system,the Redarc Trailer brake controler and wiring the Fyrlyts.
    Must say Tims kit is a dream to fit.Everything the right length and the instructions are so easy to follow.
    Im probably two thirds thru the job.All the cabling is done just need to finish it off tommorow.
    Havent seen or smelt any of Lord Lucas' smoke escaping from anywhere yet.
    Our spannerman from work,who is also an auto electrcian called by today.He was impressed with the DBS and the instructions on the laptop,reconed anybody could fit the kit!!!!!
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    LGM's Avatar
    LGM is offline Master Silver Subscriber
    May 2010
    Dongara on the Mid West Coast WA
    Test of Objectives
    If I can fit the kit, anyone can!
    Mar 2007
    Kalgoorlie WA
    Well I suppose that now I've got a bit of time on my hands, I should get around to fitting my Traxide kit. Bought it ages ago, but have never had the time to fit it.
    Every cloud has a silver lining ............................
    Cheers .........
    BMKAL
    Williams West Aust
    Didnt get as much done as planed today.Nevermind,the dual battery system is in.Will have to finish the Redarc and spotties after Xmas as we are heading up to Perth for a few days.
    A few pics.
    I wasnt happy bolting the isolator to the battery tray,also had to find somewhere for 2 circuit breakers(one is "in the mail") and the spotlight relay so I made a bracket bolting to the 2 exsisting M6 holes in front of the main battery.
    Quite happy with the battery controler/spotty switch/Redarc.
    I didnt wire the rear factory outlet into the DBS,instead I put an engel plug plus the supplied 12V outlet into the jack compartment lid.Wont be putting the jack in there any longer.Also wired my inverter into the DBS,it can live in the jacks position when not required.
    Snow Whites tail.
    She is a bloody mess,now to put her back together again
    Andrew
    Williams West Aust
    All the trims all went back together
    Started her up and no gremlins on the computer screen
    Andrew
    Mar 2007
    Kalgoorlie WA
    So now that you've successfully completed all that, must be time that you and Deb came for a drive to Kalgoorlie.
    I've got a Traxide kit that needs installing .............................
    Cheers .........
    BMKAL
    You have been a busy chap then.
    Good Work.
    Cheers & Safe trip.
    Williams West Aust
    Quote Originally Posted by sniegy View Post
    Good Work.
    Cheers & Safe trip.
    Thank you,your post on the trailer brake controler is very good and helped make the job easyer.Have the wires in the towbar cubby read to join.
    Andrew
    Oct 2003
    Montrose, Vic.
    Looks good Andy
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Williams West Aust
    Quote Originally Posted by BMKal View Post
    Shame its so bloody hot at the moment mate.
    Im off work until Jan 12,could go for a drive.
    Hoping to complete the job tommorow now Im back home
    Andrew
