Results 1 to 10 of 12
Thread: 2a engine into 1955 s1
    Aug 2008
    latrobe valley victoria
    Hey all...2a engine into 1955 s1
    I'm considering fitting a 2a engine as my 2L isn't the fittest, my query is are there any perminant mods required to fit and will a 2.2 engine bolt up to a s1 gearbox?
    Just thinking out loud lol
    Regards mark
    2002 defender 110 , 1955 86 inch
    East-South-East Girt-By-Sea
    1.20 MB
    Very common mod.
    You will need the bellhousing from a SII or SIIa suffix A box with the 2 1/4 bellhousing. Or just use the gearbox from any 2 1/4 (not SIII) externally they use the same mounts and will connect to your clutch shaft.
    You will need the radiator from a 2 1/4 or have the bottom pipe swapped over.
    You will also likely need to get the accelerator cross shaft and mechanism from a SII or SIIa to connect the carby which is on the other side of the engine.
    You can use oil bath air filter, inlet hose and elbow from the 2 1/4 which has a larger bore but the elbow may hit the under side of the bonnet.
    If your 55 is a 107 or 86 you may find the front axle housing will hit the sump.
    Jul 2009
    S.E.Qld
    Very common mod.
    And that's the reason they extended the wheelbase by 2" to 88 and 109 on later models. .W.
    smurf village
    Thanks for the info Diana , this is going to be my next project as well.
    Aug 2008
    Might just buy 44 gallon drum of oil and keep driving it lol
    Might be an idea to find someone who can hone the cylinders and re ring it.... Get the valves lapped and hope for the best..
    ----- If your 55 is a 107 or 86 you may find the front axle housing will hit the sump.
    You can lift the engine away from the axle housing a bit by using a pair of rubber engine mounts from a Toyota FJ40, but watch the underneath of the bonnet, this in turn can be lifted a bit by adding spacers under the radiator support panel and straightening out the bonnet hinges a bit as well.
    Quote Originally Posted by mfc View Post
    Make sure the inlet valve stem seals are replaced first, as these seals are a common source of oil usage problems.
    Aug 2008
    I've done the seals and lapped in new valves...... I didn't think before but it could be the valve stem guided.... ( do they have them on the exhaust valves )... Anyhow I've got a set for I'm assuming the inlet valves......
    Exhaust valves do not have the potential of oil usage that inlet ones do - the exhaust pressure tends to push oil back up the guides, inlet, the manifold vacuum tends to suck oil in - and is often very effective at doing so! Also, on this engine, gravity helps oil run down the guides on the inlets, hinders on the exhaust.
    Aug 2008
    Cheers john . Am I right in recalling that there is no valve guides on the exhaust valves? If so I have a new set of inlet valve guides( although without the valve seal grove inside them , ie earlier 2l engine) ... Doesn't even smoke in normal driving but if left idling for a while it lets out a billowing cloud for the first 50 meters lol , that I asume is oil buildup getting sucked down the valve guides..
    Might have to get valve seats and valves and seals from the uk...
