Originally Posted by
landy
Hi,
The bits in the middle are spacers to lift the suspension. They are bolted under the front or rear spring saddle. You will see two bolts holding the spring saddle to the axle at the front and rear.
The yellow bits are also for lifting the suspension but they just sit under the spring and are held in under spring tension. They lift the height equal to the thickness of the spacer.
Nino.
Hi Landy/Nino and many thanks. The round steel bits are a wee bit larger than the internal diameter of the yellow bits, so will initially sit inside the yellow bits almost at the bottom, and no doubt soon both will be flush at the bottom in the saddle for my slight lift.
Edit. Have just realised that the steel bits will no doubt be bolted down tight at the bottom to be flush with the bottom of the yellow bits.
Reason: correcting words
