Results 1 to 10 of 16
Thread: Heat Gun - what's hot and what's not!
    Mar 2014
    I am slowly expanding some my workshop tool kit. Having borrowed my brother's heat gun a few years back I am now looking at buying one myself for things such as shrinking plastic tube, softening plastic tube, drying (gently), paint stripping etc. Happy to take advice from anyone with expertise or even bad experiences with a product. Bunnies and Master have them for $39 all the way up to >$100 with similar specifications, so what are the differences?
    Thanks in anticipation
    St Helena,Melbourne
    4.28 MB
    I would just get a cheapy , i have a ryobi that rarely gets used but i would an ozito or similar if i was buying now.
    Sent from my GT-I9300 using AULRO mobile app
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2008
    Bundaberg Qld
    X 2, The ozito (a Bunnings brand I believe) is great value and has a good warranty. Obviously not "top of the range" quality, but for the amount of use mine gets it is ideal.
    Jun 2014
    Dubbo
    The dearer ones will usually have greater temperature and fan speed control. Ive got a green Bosch, about 5 years old. It has 3 fan speeds and a temp range of 50-630?C adjustable in 10?C increments shown on an lcd screen. Probably not always necessary to have that much control, but it can be handy. My girlfriend even used it as a hair dryer once!
    Tom
    May 2009
    Tatura, Vic
    I purchased a Makita one about ten years ago. This was the most expensive of the lot but I liked the variable heat setting. It has had a lot of use and still works like new.
    If you don't intend to use it often a cheapie will probably be ok.
    There is an old saying.
    The bitterness of poor quality remains long after the price is forgotten.
    So to me it depends on what you can afford. If you can, get better than a cheapie.
    About 10 years ago I purchasd a 12 volt cordless drill from Bunnings. It was an XU1 brand, which I think was their own brand, like ****ito.
    After about three weeks and there was nothing wrong with it, I chucked it out.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Mar 2014
    Hey, telling my wife she can use it as a hair dryer makes it seem like the heat gun is not just for me. I like the way you think!
    I bought a GMC about the fourteen years ago. It died last year.
    During that time I used it to do the same job as steamer to make it easier to bend and twist strips used to build ten strip built kayaks. That adds up to a huge amount of time and equates to about $3 or $4 per kayak.
    In my experience the temperature needs to be adjusted partly by varying the distance between the gun and the work.
    I replaced it with an Ozito. I doubt many DIYers would use heat gun more than I do. I did use it for a number of other jobs like stripping paint.
    An expensive one would need to last me about 40 years to offer the same value for money.
    The cheapy did the jobs I needed it to do.
    Nov 2010
    pannawonica
    I still use a Makita, had it atleast twenty years of occasional use.
    Geelong, VIC
    My old XU1 lasted more than 10 years, and have just recently replaced it with a Ryobi for $49.
    The Ryobi was the only one at Bunnings that didn't have a stupid bulky trigger guard.
    Mine often gets poked in tight places behind dashes or in engine bays doing heat-shrink on wires, and I felt the guard was going to prevent me from getting the heat where I wanted it.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    May 2009
    Tatura, Vic
    My XU1 was in perfect working order when I threw it away. This was for a number of reasons.
    Had one battery that would take 3 hours to charge and then last five minutes. Didn't have a two speed gearbox.
    At around the same time I also purchased an XU1 240 volt drill. I was drilling a piece of half inch thick steel and it got that hot it caught fire.
    GMC.
    10 years ago I purchased a GMC nine inch grinder. ($150) As I don't use the nine inch that often I thought it would last.
    I had to do a small cutting job on some concrete. The blade jammed and I immediately removed it. Game over.
    It was about three years old, still looked new as it had done such little work.
    Out of warranty so stiff.
    Not long after this my 6x4 trailer got hit up the arse and bent the draw bar. I needed another grinder.
    At the time GMC had a return policy, from memory 14 days. You could return a used tool no questions asked
    So I decided to buy one, use it and take it back. Bunnings did not have a 9 inch but they had a 7 inch so I reckoned it would be big enough.
    By the time I finished removing the draw bar the gearbox in the head was stuffed.
    My last 18 volt cordless drill was a GMC from their platinum range. These are the heavy duty ones. They did last better but have not come close to my Makita 18 volt.
    Now I know you can buy a handful of cheapie's for the cost of a quality drill so over time the cost is similar, except with a quality drill it will usually be more ergonomic and lighter.
    A lot of my cheap drills have actually out lasted the battery in which case it is cheaper to buy a new drill.
    My Makita recently had a battery die. The drill is still going strong and it was worth getting a new battery.
    For my 9 inch grinder. I went and spent $300 on a Metabo. I expect it to last long enough to be able to hand it down to my son when I fall off the perch.
    So this is my take on power tools. Have had a few and come to the conclusion that quality is better value.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
