Results 1 to 2 of 2
Thread: swapping 3.5 to 3.5 efi?
    Myrangie76 Guest
    Hi guys need your expertise on something my engine blew up this morning.and found a good second hand efi 3.5 would the engine be straight bolt on or do I have to modify stuff plus what else I need to change on the car well I.know I have to change the fuel pump and fuel lineso what else? Your help will be much appreciated thanks
    St Helena,Melbourne
    4.28 MB
    You can use your carby intake on efi motor otherwise you'll need tank ,lines ,pump,ecu , maf and wiring loom.
    Sent from my GT-I9300 using AULRO mobile app
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
