Hi C00P ... Your 1080watts calc is correct as that is the input power (P1) .... To give you an output power (P2) of 750watts. About a 70% efficiency.
The EU20i Honda inverter generator will go 50% over it's rated maximum output for 1 - 3 seconds for motor starting duties. It will start and run your Onga without any issues. I have been able to start and run 1500watt pump sets from an EU20i.
I would leave the Eco throttle setting at OFF so the EU20i is running at full speed when the pump starting load is applied. With Eco throttle on, the time it will take for the EU20i to respond to the starting demand the pump is asking for, and get up to a suitable operating speed, may cause the EU20i to go out on fault. There's no issue with the Honda Inverter generators if you overload them as they will just disconnect the power output, requiring a stop/restart.
How do I know this ? I have a Honda Power Equipment dealership, and the other half of my business is pumps, irrigation and plastic plumbing supplies .... Been doing this for 28yrs.
If you don't have the EU20i yet, suggest you look at the EG3600 unit. It's bigger, a bit noisier, but is 3600watts output for around the same money, and will will leave plenty of extra capacity to run other appliances simultaneously ... Also runs a large long range tank.
Kevin
Sent from my iPad using Braille
Kev..
2014 Isuzu MUX LST with fruit
2008 Isuzu D-Max
2015 Kimberley Kamper "Classic"
Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
