Thread: Unstable reving when coming to idle
    Aug 2013
    Rockhampton, QLD
    TD5 Auto - So when coming to a stop when the car comes down to about 20km/h the engine seems to cut in and out a bit, starts a sort of grr grr grr as it comes to a stop then idles properly. Only does it when decelerating.
    Ive seen other people online in other forums mentioning it also but I have never seen a reason for it, I have also heard other TD5s do in when then drive near me. Its always done it, and doesnt seem to be causing any issues, I am just curious what is going on.
    Thanks.
    Nov 2014
    Nirvana near Albany W.A.
    ecu is cutting. fueling to injectors on overrun
    Aug 2013
    Rockhampton, QLD
    Ah OK. So its normal or some cars are doing it wrong?
    Sent from my Nexus 5 using AULRO mobile app
    2003 D2a TD5 Auto
    1960 Series 2 Petrol
    Nov 2014
    Yep , perfectly normal , td5 s make the clatter due to the camshaft operated unit injectors , some common rail cars will shut fuelling on overrun as well but no noise because pressure on common rail is due to a pump
    Aug 2013
    Rockhampton, QLD
    Awesome, thanks for the info!
