Page 1 of 22 12311 ... LastLast
Results 1 to 10 of 211
Thread: Drop axle on caravan
    Aug 2010
    Sunbury, VIC
    Just after some advice/opinions on what is the best (not necessarily the cheapest, but lower cost is always good) way of increasing the ground clearance of my ye olde caravan a couple of inches. It currently has the original 2" drop axle in it. I'm thinking the only real way is to fit a new axle or cut and reeled the drop bit off.
    Any ideas appreciated.
    May 2003
    On The Road
    if the shackles will fit, a new axle would probably be best, need to change the tongue?
    Western Victoria
    Is it possible to extend the shackles on that van? That should give you an extra inch.
    Are you going to change the position of the hitch?
    Moruya Heads/Sth. Coast, NSW
    Overhang front and rear is the main problem even with lifted springs, etc.
    I seen an off-road caravan (about 16') and the body was high as Mt. Everest, but it still bottomed out on the drawbar and rear steeply angled rear end, might gain a bit with springs on top of axles. Caravans are just not suitable off road, Regards Frank.
    Western Victoria
    Quote Originally Posted by Tank View Post
    Thankyou for your input but I don't think that had anything to do with the question.
    Aug 2010
    Sunbury, VIC
    It's not going off road - but it is really low, and to hitch it to the 101 will be impossible if I don't bring it up a bit. Eventually I plan to modify the draw bar, but I'll make up a tow bar that drops down on the 101 for the time being.
    The water tank is barely 100mm off the ground, so it is really low - I just want to bring it up a bit so getting in and out of parks, etc won't cause too much grief - I can't even get it up my driveway at the moment without it scraping.
    Aug 2009
    Sunbury Victoria
    My neighbour needed his Jayco lifted to bring it up to his 4wd. He got it done professionally and what they did was to weld some 2" box tube to the chassis which dropped the whole suspension down.
    Cheers, David.
    My Land Rover has made me a better Mechanic........
    D2 TD5 Manual, CDL, Detroit Rear, Truetac Front, 2" OME lift, 32" MT Tyres, ARB Bull Bar, Winch, TJM Roof Rack, Driving Lights, Dual Batteries, ARB Side Steps, Rear Draws, Uhf.
    Aug 2010
    Sunbury, VIC
    Well I think my decision has just been made for me. Just looked at the brakes to see what needs doing to them - but they are toast. As I'll need to replace these in their entirety, I'll go the extra distance and get a new axle while I'm at it.
    Another question - any ideas how to clean the water tank out so I can reuse it? It had water in it, so I know it doesn't leak, but I'm not keen of using it again until I know it has been fully decontaminated from years of sitting doing nothing.
    Cheers.
    Perth WA 6149
    Subject to hub/drop axle clearances you may be able to flip the axle to mount below the spring.
    Steve
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by Rok_Dr View Post
    Steve
    Thanks, I did some quick calcs on this. Putting the whole axle under the spring gives me about an inch - a good start, and flipping it over gives a huge amount, but it wasn't sure if it would stay flipped if I set it like this. Would it survive the natural tendency to want to revert back to the dropped position? If you know what I mean?
