Results 1 to 10 of 22
Thread: td5 running problem riddle
    Apr 2010
    Adelaide, southern foothills
    Here's one for all you keyboard diagnosticals who love a challenge!
    My wife has the td5 with the kids on a short trip and was approached today in the main street of Moonta SA by a gentleman having problems with his 2000 td5 and looking for answers. I spoke to 'Simon' on the phone and he has had to stop "about 10 times" from Mildura to Moonta (500kms or so?).
    He says it starts to chug and vibrate then it cuts right out. He waits 45min then it starts up and off he goes.
    He says he had the FPR and crank sensor done in Mildura, they told him the ecu plug is not oily.
    He doesnt use water or excessive fuel or blow smoke.
    His fuel pump "has always been noisy" and the filter has not been changed.
    He doesnt know if the intercooler hoses were looked at.
    He suspects water in the fuel although the water trap alarm doesnt come on.
    He is sending me an email tonight with anything relevant he can think of.
    Waddayafink? I'd suggest another look at the ECU and then the hoses, a filter change and a fault code scan. What else? Do fuel pumps play up like this?
    My wife suggested he call in to Peter Brown or TRS when he gets to Adelaide which he may do.
    Apr 2010
    BTW 'they' are the RAC in Mildura apparently.
    Free Again Thanks Dan
    My money is on the fuel pump
    Apr 2010
    Is there a way of checking the fuel pump pressure and flow rate on a td5? Being an ex Ford mechanic I know how to do it on a Falcon!
    Apr 2010
    Here is the email I just received from the gent. I have also asked him which are the green lights that flash just before the problem happens, so I'll see what he says. (I recommended that he sign up to AULRO):
    "Hi there David,
    Thanks for sparing me the time to speak about the dodgy diesel system in my car. Please convey my sincere apologies to Catherine for accosting her in the street and asking her lots of questions about the LandRover. I do hope I did not delay her too long.
    If you are going to post on AULRO (for which I am much obliged) the following may add some clues.
    1. The two green lights seem to predominate in this problem and have often given me problems before but not to this extent. (I use the lock/unlock sequence to get out of it.)
    2. First started to cause a major problem shortly after coming from Sydney and travelling from Yass, through to Jerilderie and up towards Robinvale where it first came to a halt.
    3. It was the start of that very heavy rain at the end of last week (9th,10th & 11th)and I drove through the rain continuously from Yass.
    4. I got about 50 km short of Robinvale and I started to feel a strong vibration a bit like going over a corrugated road.
    5. I pulled over to the side of the road and the engine juddered to a stop.
    6. I tried to start it but it just started to run like it was on one or two cylinders and just juddered to a stop again.
    7. Called roadside assistance and was eventually taken on a trailer into Robinvale.
    8. RACV in Robinvale did not have a computer diagnostic machine so on the Monday they put it on another trailer and took it to Mildura RACV where they had a machine.
    9. The vehicle spent the next 5 days at this garage where they checked the fuel system and found a bad leak coming from the fuel regulator. This they replaced.
    10.A subsequent road test revealed an engine miss but no fault codes became evident.
    11.They cleaned the injector loom front connector and replaced the diesel soaked crank angle sensor.
    12.They noted that the fuel pump is very loud and the fuel pressure is 20% too high (100kpa)
    From my observations I note the following.
    1. Throughout all this, the engine temperature gauge did not move and stayed at 3 O?clock
    2. The ABS warning lights (the 3 amigos) constantly on and always were.
    3. Prior to this incident, I would often at slow speeds in a carpark or similar situation, have the engine stop on me and the two green lights start flashing on.
    4. Recently however on this trip I noticed for the first time the Transmission temperature warning light flickering on and off but only for a second or two.
    Further information that may have a bearing:
    1. About 3 or 4 months ago I picked up the wrong hose at a servo and put petrol in the tank by mistake. The car was not started but trailered to a nearby garage where the tank was drained and the fuel filter at the back was replaced. It made no difference to the running of the car at the time.
    Well David, that's about all I can tell you. I figure as a mechanic you may possibly see a pattern form there and the answer might be very simple. I hope so.
    I look forward to hearing from you.
    Kind regards
    Simon"
    MarknDeb Guest
    Yep sounds most likely the fuel pump but it is a Landy so it could be another thing guising itself , Easy way to check fuel pump is turn ignition on and listen to the pump, if the pump takes more than a minute to pressurize or runs for ages its done, when mine went it took about 3 minutes to run up
    Apr 2010
    Yes the pump in ours was noisy and ran for ages with the key on just before it packed up. Interesting that the RAC said the pressure was too high.
    The fuel pump making alot of noise is the give away , They do make a noise but more of a whirl than whine .
    Tell him next time it stops to cycle the ign then get under the rear and belt the fuel tank and if the pump starts good chance the engine will .
    The pump still needs to be replaced ASAP
    Jul 2014
    west of Transylvania
    Quote Originally Posted by Davetd5 View Post
    Yes, to screw in a gauge instead of the temp sensor in the FPR, there must be 4 bar or above, the engine will run with lower pressure too but not well
    as long as there are no fault codes logged it's more likely that it's a fuel delivery issue cos that's not covered by diagnostics... that symptom can happen if the injector washers/seals are worn as well and there will be no faults logged either
    Dec 2008
    Geelong, Victoria
    Never rule out intercooler hoses. Watch or log the airflow readings. Mine went to zero when engine lost power.
    Sent from my GT-I9100 using AULRO mobile app
