Results 1 to 10 of 27
Thread: pressure washer
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    pressure washer
    am well and truly over my karcher 2.91 and it never wanting to kick in
    whats a decent home duty pressure washer that is reliable?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Replace the pressure switch
    Usually a good solid unit...
    Or just grab a Gerni equivalent...
    Jun 2008
    Sth East Sth Aust
    Not sure on the models
    I have an old (15y) Karcher HD model that is still great
    Bought a small one for home new Karcher last year
    1 yr later it failed
    Bought a Stihl mid range - very happy, good build quality, reasonable price
    Can buy spares etc
    Nobby
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    you've had a better run than me then
    i'm on my 3rd switch and it's gone again..
    PIA
    Feb 2013
    Ballarat,Vic,Aus
    I have the smallest karcher you can buy .... There is two models. They look almost the same, but one is chinese crap, the one I bought it made in germany from memory. It comes with the really high pressure wand with a rotating ball type head which is nothing short of brilliant. It will strip the paint from any surface ....
    People are always borrowing it, and it's never failed to come back in working condition, which is highly unusual. Usually everything I lend out comes back stuffed. So it can't be too bad
    seeya,
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    bought a little gernie that was on special...
    model 120.4
    yet to try it... will let you know
    Oct 2007
    Brisbane West
    I have had a big Ryobi unit for about 10 yrs...heaps of grunt and it gets used weekly sometimes non stop for hours cleaning cement. Its a re badged Italian jobbie with stainless pistons. Wand and hose and fittings are very heavy duty.
    Oct 2007
    Brisbane West
    To keep them going keep the trigger pressed and turn off at the machine and to turn on operate trigger first...stops pressure switch assembly seizing.
    Mar 2014
    Spitwater
    I bought one of these, model 10-100 quite a few years ago and it is brilliant. Simple, no fancy coloured plastic covers, powerful, never needs a break.
    The hoses and fittings are high quality and do not kink.
    I concur with ozscott in that I try to remember to have my hand on the trigger when I start the motor and always drain the pump uf pressure when I turn it off.
    Cold Water Electric - Commercial
    Not the cheapest purchase but been value for money.
    They make cheaper and more expensive models and in petrol also.
    Last edited by Blinky; 23rd January 2015 at 03:21 PM. Reason: typos and more detail
    Douglas Park, NSW
    Quote Originally Posted by incisor View Post
    model 120.4
    How's the new one travelling?
    After working for Karcher years ago I was all set on buying one of their upper end domestic models but after some research I'm not so sure now.
