Results 1 to 3 of 3
Thread: Choice of Code Reader \ Eraser etc Disco 3
    Jan 2015
    Penrith
    Cool Choice of Code Reader \ Eraser etc Disco 3
    Hello,
    I suppose the question has been asked a trillion times:
    What is the easiest way and from whom should I approach to purchase a proven reputable device for reading ~ removal of all error codes on a Disco 3.
    I have seen the Blackbox sites for the Faultmate MSV Nano and the Faultmate FCR but the prices are pretty heavy. I am looking for contacts please. Are there alternative brands with the same functionality. After recent experience with a clapped transmission module I would like to have an interface in my kit onboard when we head around the block with caravan in tow .
    Don
    Ean Austral Guest
    I have a hawkeye from bearmach which I bought direct from the UK thru ebay.uk.
    I am unsure whether its better/worse than any of the others but it lets me see live data and read/clear the codes which is all I wanted. I have seen mention of other scan tools but the Faultmate and the Hawkeye are the 2 that I hear mentioned most.
    The exchange rate wont do you any favours at present but personally I believe a code reader to be the first tool you should have for any late model car.
    Good Luck with it.
    Cheers Ean
    Dec 2009
    Ranelagh, Tasmania
    IID Tool from GAP Diagnostic IIDTool for Land Rover - GAP Diagnostic, easy to use and does just about everything you could need from a scan tool (calibrate suspension, set tight tolerance etc)
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
