Lots of people here will have smart advice for you. There are lots of D3 s on here with those kinds of kms, but having said that thats getting up there, you need to make sure the price is commensurate with the high kms. You will need to make sure that at those Kays it has had the transmission oil flushed at least onece, preferably twice and has the steel transmission pan, it should also have had the timing belts and the coolant pump housing changed at about 160,000kms from memory.
I would also like to see it haveIng had the air compressor replaced with the newer model.
Also get the front lower control arms checked for wear. And if the shock absorbers haven't been replaced they will be in the way out and that can be a fairly costly excercise in these cars as it is a toss up between paying the labour for the fiddly job of replacing just the shocks which sit inside the airbags, or paying the money to replace the whole shock and airbag unit but less for the labour for the simpler job.
Make sure you take it to a mechanic familiar with these cars to check it before you buy it.
					 ) turbo, p/steer, RFSV front axle/trutrack, HF, gullwing windows, double jerrys etc.
