Results 1 to 6 of 6
Thread: Cannot input into GPS while moving
    kush47 Guest
    Angry Cannot input into GPS while moving
    Does anyone know how to disable the feature that will not allow any data entry into the Freelander GPs while moving? It is a very annoying feature. It means that even the passenger cannot enter or change a destination while moving.
    It's not just the GPS on our Subaru, it also locks out the phone.
    Try this trick which works on our Subaru - pull the handbrake on very slightly. I'm going to disconnect the handbrake switch which connects to the GPS so that I don't have to pull on the switch.
    Dunno if it will work on a Freebie but it's worth a try.
    Sep 2012
    Adelaide Hills
    chances are it does work, but just reconnect it if you have an inspection as its a defect.
    Quote Originally Posted by Eevo View Post
    I think the Suby has two switches, one for the dash brake warning light, the other for the GPS. If not, I could wire in a hidden bypass switch.
    Quote Originally Posted by kush47 View Post
    Gap's IID tool can enable / disable 'Nav on the Move'. Not sure if they support Freelander though.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    kush47 Guest
    Wink
    Thanks. I'll look into it.
