Results 1 to 2 of 2
Thread: Suspension Height Warnings
    Oct 2013
    Castlemaine, Victoria
    Have been scanning the posts and I'm not sure what to make of my problem with my 2011 D4 111,000km
    The day after a wheel alignment by a LR dealership (3rd attempt to get it right) I hitched the caravan up and drove off. The 'Only Normal Height Available' warning appeared. Indicator light "out" on suspension height selector.
    Stopped & turned ignition off. Restarted and drove away but message reappeared shortly after. Warning remained on for the entire journey of 60km or so. It comes on regularly now soon after moving off.
    I have also had the "Reselect Suspension Height if Clear of Obstacle" warning when stationary in my driveway. Prior to the above warning, a different warning appeared, something like "Suspension in Extended Mode". I got out and checked the vehicle and it appeared that the front was at normal height, and the rear at off-road height.
    This warning is also appearing "Vehicle Raising In Progress".
    The car had been parked in access height. Selected normal height when leaving car park. This message would appear every 30sec or so for a couple of km.
    Perhaps it could be associated with the wheel alignment or, the timing of the problem may be coincidental. It might be relevant to mention that it took the workshop three attempts over several weeks to get the straight ahead alignment correct on the car. Finally this has been rectified and, with the steering wheel centred the car is tracking straight ahead.
    Just taken the car for a short trip before finalising this thread and it seems that the front suspension is now stuck in access height and the rear normal.
    NSW SW Slopes
    The front is probably still raising, albeit very slowly. See my response in your other thread.
