Results 1 to 4 of 4
Thread: LPG on 98 5 litre Holden
    May 2006
    Ulverstone,TAS
    Can anyone tell me if it's worthwhile putting lpg on a commode 5litre v8. Will be using it to go from Batemans bay to Eden and back nightly.its for work and don't get paid fuel allowance.😢
    Sent from my GT-I9505 using AULRO mobile app
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Safety Bay
    Mine drove better on LPG than petrol,you need to change plugs and give it a bit more advance,why don't you use the Td6,it'll burn under 9ltres per 100 and cost you nothing to set up. Pat
    Crafers West South Australia
    My neighbours put 400,000km on their VT 5.0 before they traded it on a VE, it didn't have any engine wear problems. They're a good motor for gas. You should be able to find a used kit at a wreckers for a few hundred and get it fitted somewhere. A V6 kit is very similar except for the wiring connections to the engine, it shouldn't take much to fit one to a V8.
    May 2006
    Ulverstone,TAS
    Hi Pat, it's a ute... will have a dog cage with dog on the back.😎
    To bee utey, thanks for the info.I used to have an xf ute that I put gas on, it burnt the valves after awhile.😡
