Results 1 to 3 of 3
Thread: Steering column surround
    Kyvalley
    Hey all,
    just trying to chase a fault with an aftermarket bluetooth fitted to our 09 D3. I need to remove the dash trim - the centre section no problem as it's well documented on the inter web thingy. The section around the steering column is proving a little more challenging. I've removed the lower panel and the two torx screws, but I'm not game to pull too hard unless I break something. Am I on the right track?
    Matt
    NSW SW Slopes
    There is another screw towards the centre rear. You might need a torch to see it properly.
    Kyvalley
    Thanks, I'll have a look
