get it up to 100km's and let your foot slip off the throttle,is it the same thing.because that is what happens when the cruise disengages
Evening all!
Quick question on the cruise control system on the D2...
I have found that when I disengage cruise control, either through braking/hitting 'Cancel'/manually disengaging through the binnacle button, it seems to do so 'aggressively'...ie: with a sudden jolt. Should I attribute this to the age of the vehicle (2000) and it's system? After being on holiday for the past fortnight and hiring three different vehicles, all with CC that is barely noticeable when it disengages, mine feels prehistoric in comparison!
Anyone else...?! Answers on a Rizla, please!
Chars!
Kev F![]()
Darwin
03 disco 2a td5
93 tdi disco [gone to a better home]
2003 d2a v8 retired hurt
1988 k100rs bmw gone
85 county izuzu [gone to a better home]
69 series 2a [gone to a better home]
series 2a [gunnado]
series 3 [gunnado]
and the tinny
mine is not to bad as it is a v8 auto,I notice you have a td5 yours will be possibly worse.but you are correct the modern cruise is not as violent
Darwin
03 disco 2a td5
series 2a [gunnado]
series 3 [gunnado]
and the tinny
The cruise isn't brutal - it just turns off.
And driveline play takes over!
Easiest is to kill it using the wheel controls where possible and have your foot already taking up the throttle.
Mine shows a perceptable difference as well...... But not a bad as Lady Penelope though which is a real slow down coming off cruise.
Roof racks, other gear hanging off the car and fat chunky tyres will also contribute as well to de-acceleration.
Steve
I know what you mean,. My wifes MX5 is seamless when it is turned off but my TD5 is very noticeable.
Just wondering if it's a manual? If so, any chance your foot was resting lightly on the clutch?
Sent from my GT-I9100 using AULRO mobile app
Yep mine is the same. Plenty of driveline play when you switch it off. What I do now is accelerate a little bit, then switch off via the steering wheel control.
That way you don't get the shudder with it.
