Results 1 to 10 of 12
Thread: PTO winch questions
    Dec 2011
    North west NSW
    PTO winch questions
    My truck came with a winch but no cable, I have managed to get the drum turning and will source some cable in the next few days.
    But am i able to drive under winch or will I just have to drag myself out of trouble disengage winch then drive away?
    Ben
    Hay Point
    Hi Ben, you can use any gear you like including reverse while you are using the pto. Low gear + low range is excellent for assisting the winch pulling yourself out of a bog etc. Then you can throw the transfer in neutral and retrieve the cable with 4th gear if you want. Very versatile and you can use it all day - unlike the electric jobbies.
    Cheers......Brian
    1985 110 V8 County
    Dec 2011
    North west NSW
    Leads me to my next question, how much cable and what diameter are people using??
    Jul 2008
    I guess it's a thomas pro. With mine I can fit about 70-80mm 8mm wire rope or about 50m of 10mm dyneema.
    Clive
    Jun 2014
    Waitakere, New Zealand
    According to Dave's buyers guide (which you should buy, even if you already own a Perentie) both the 4x4 and 6x6 came with 45m of 11mm steel cable.
    For some reason I thought the 4x4 came with 10mm and the 6x6 came with 11mm. Someone might be able to clarify this..
    Edit: Thought I had read it somewhere
    http://remlr.com/forum/index.php'topic=2513.0
    The rps states 10mm for 4x4 and 11mm for 6x6 both 45m.
    Quote Originally Posted by BadCo. View Post
    Perentie 110 PTO & Winch
    The ropes were originally different but to simplify supply when the cost of the 6x6 rope dropped to the same as the 4x4 rope if you mangled the rope on a 4x4 then the 6x6 rope was provided as the replaceement
    Dec 2011
    North west NSW
    Can I fit dyneema/synthetic rope to the ribbed drum on the PTO..??
    Thanks in advance.
    Ben
    Dec 2011
    Adelaide
    142.79 MB
    You can probably fit Dyneema to the drum, but I'm not sure how it will go with the rollers.
    Aug 2011
    I can't see a reason why Dyneema would not work on the winch. But (as Aussie Jeepster said) the rollers might be an issue. The original concern with Dyneema was that winches with braking systems that got hot might melt it, but I don't think that applies to a PTO winch?
    Most winches sold with Dyneema don't use rollers, just a smooth alloy oval fairlead system, because synthetic rope runs over polished alloy very well. Because it can flatten, if it finds a gap in the corner of the rollers it might fall in, but as long as there is lots of overlap between the horizontal and vertical it would probably be fine...... But make sure the rollers are nicely polished, if they're rough from wire rope scoring them they might slice the Dyneema up!
    Apr 2012
    samford
    Quote Originally Posted by clive22 View Post
    Clive
    IS this what the army 110's and 6X6's came with?
